OK...Got a few different map paks suggestions to use for fuel pack, from Vance and Hines, if anyone has the same setup! I've got K&N high flow air, Fuel pack, and V&H competition 2:1 standard baffle part number 75-106-9 on a '09 NRS STOCK 76cc!! All i'm looking for is the FP-XXXX code for setting values for the ECU.. if anyone has this set up just let me know what you are running thru map pak.
Thanks and regards!
Thanks and regards!
