Disclaimer: I own a 2008 VRSCDX, and have another 2009 VRSCDX in my garage next to mine that a buddy owns. I have worked on bikes for years, and was helping a friend out who has a non V-rod.
Ok first the bike is a 2002 GSX-R, second been riding Hatrley's since I was 9 and 33 now. Also I do major work on bikes, but not crouch rockets so much. This bike is a friends, who needed these two things done.
Next the things done were and oil/oil filter change, and new spark plugs.
After the new spark plugs were in, and airbox all back on, I started on the oil, drained and oil filter replaced. New oil put in, and cleaned bike up where it needed it from oil drop drips.
Backed bike out of garage, started it up without any of the fenders/body pieces on it, and let run for 10-15 min. to burn any oil drops on the exhaust off.
NOW THE ISSUE...
I put the rear, and side fenders back on. And then the front fender and hooked everything back up. AKA two turn signal connectors and the three others that go to the gauges. One was a gray one, easy as it was the only style connector, the other two were the same style, but was only able to connect one way as there was not enough slack to flip and connect the other way.
The bike will not start now, and the main gauge does not light up. The main headlight does come on, and if high/low beam switch is used it does change the beam direction and a high beam indicator does come on.
Turn signals also do not work.
The fact the main head light comes on when the key is turned tells me it's not the battery, so I have no clue what is doing this.
I also disconnected everything, as it was when running before, and now it does not start that way either, nor does it make any electrical sound when the key is turned to on and the on switch is used.
What am I missing in regards to this????
Help please, friend wants to pick up tomorrow mid day.
NOW THE ISSUE...
