1 - 2 of 2 Posts
My plan is to eliminate the separate rear turn signals and side mount the license plate. I‘d like a light similar to the Custom Dynamics integrated light that no longer seems available.
I considered updating existing light to led and adding led strip turn signals under the fender. I’m assuming the side rails under the fender are removable.
Any suggestions for possible replacements or products or places to look into?
Advise is greatly appreciated.
Hello,
I have used this LED brake light with integrated turn signal for my VRSCA, he also sells the same kit for later models. Works great, I did not use the supplied resistors. I purchased the biketronics smart equalizer and it works perfectly.
To install you either need to cut the bag mounts or remove them either way then it’s a quick install. Wiring is easy, I would suggest getting the Harley wire clips so you don’t need to splice into the harness wired.
Lights
LED Fender Eliminator Integrated Tail Light Smoked Bar For Harley V-Rod V Rod VRSC/A 2002-2005 - AliExpress Mobile
Biketronics
Lighting Control - Load Equalizers - For LED Lighting - Biketronics Inc
1 - 2 of 2 Posts
