1 - 2 of 2 Posts
03 Anniversary Edition
These are probably pretty simple procedures, but I wanted to get some advice before I start.
Clutch Lever: I know that there is a little spring that has to be removed first, but, if I don't have the bent needle nose, how do i remove it -- and then what is the rest of the procedure?
Right Front Signal: The bullet shaped signal that hangs from the master cylinder assembly on the handle bars actually hits and dents my airbox cover on a full right crank of the bars. (The left side has about 1" clearance.) How do I adjust it so that there is ample clearance, and while I am at it, I would like to change out the steel/alu shaft that they hang from to chrome. Any advice as to how to do this (and where to get the chrome shafts and bolts, etc.) will be greatly appreciated.
Thanks very much.
Steve
Discussion Starter · #2 ·
By the way, dmlkm your bike is ridiculously beautiful. Where are your front turn signals?
1 - 2 of 2 Posts
