1 - 3 of 3 Posts
F2NV
So I have a 09 vrod muscle, with vance and hines slip ons. I have the pc5 with autotune. I have loaded the map from power commander, 15-006-009.
I filled up the tank have ridden about 90 miles and the range is saying ~20 miles til empty. I stay in 2nd and 3rd gear and stay ~5-9k rpms only go lower if Im just cruising. I also have a 26t sprocket.
I expect worse fuel mileage when staying in higher rpms but wasn't sure if it should be this bad.
Do I need to adjust the map? Is my gas gauge maybe off (I know they have a history of being faulty). Or is this normal?
Any thoughts?
TIA
Everything you have done including your riding habit of 5-9k rpm. will decrease fuel mileage drastically. these bikes suck fuel at high rpm like crazy stock with a 28 tooth sprocket. Also you need to calculate mileage by dividing gallons used into miles driven. Not the inacuate gauge.
Any thoughts?
TIA
Move you cruise afr up to 14.2 and auto tune that area. This is generally in the 10-20 tps% range of 3500-5000. The 26 tooth is also killing mileage as you know. 5-9 k in second and third is serious rpm overkill, staying there. I'm usually chugging through towns in third at 3k . Due to traffic around here in 5th 3750-4200 rpm. Don't believe that nonesense about these engines need to rev unless you like lots of noise for no reason. It's usually the cop out for a bad tune, where the engine will not run right at lower rpms.
1 - 3 of 3 Posts
