Hello, im searching ABS full module or only mechanical part.
Parts numbers:
48344-09 HYDRAULIC CONTROL UNIT
40649-08 ELECTRONIC CONTROL UNIT
Parts numbers:
I doubt you need both. The HCU is what fails. New part number is 48344-09 A. Likely a different supplier.
Warning, you will need to take the bike to the dealer so they can "marry" the ECU to your bike's main ECU if you replace that. It's a procedure done with the their Digital Tech 2.
And in case anyone cares, yes I DO have the codes to do this procedure, however it's such a rare operation I haven't put it into one of my products.
I agree with Ron, that is one part of these bikes I have yet to see get toasted. Are you perhaps trying to retrofit ABS onto a non-abs equipped bike?
