1 - 1 of 1 Posts
Vendor
Introducing some of the most popular Torxe products available at our store: an AGM factory-activated battery and a 12V battery jump starter. There are tests that can tell you whether you need a new battery or not. If you know how to use a voltmeter and the test proves that you need a new battery, we have tons of options available. We recommend using more advanced AGM and gel batteries which are spill-proof and much more durable.
In the situations when you turn the key and nothing happens, a bad battery is the culprit most of the time. Sure, the problem might be in the charger-rectifier or the alternator. In this case, a reliable portable starting and charging device will save the day. Take a look at the reliable Torxe jump starter.
Torxe™ - 12V Battery Jump Starter
Specifications:
D/C Voltage: 12V
Battery Type: Lithium-ion
Features:
Powerful, lightweight lithium-ion battery technology
Spark-proof and reverse polarity protected jumper cables
Includes 12V car charging adapter and AC charging adapter
Jump starting/recharging cycle life: 1000 cycles
Two 5V 2A USB ports for charging cell phones/smartphones and other mobile devices
Cell phone/smartphone charging cable with adapters for all common mobile device charging ports
12V, 16V & 19V charging port for laptops, monitors, cameras, etc.
Includes charging cable & 8 charging port adapters to cover all brands and types of electronic equipment
Built-in LED flashlight with flashing mode on power bank
LCD display shows percentage of power and output voltage
Portable air compressor with integral pressure gauge
Compressor includes 20” power cord and 4.25” air hose for easy tire access
Compressor includes built-in LED flashlight
Includes inflation hose adapters for airing up sports equipment, camping gear, etc.
Compact, hard plastic carrying case with handle has separate compartments for power pack, compressor, and all accessories
Operating temperature range: -13ºF - 176ºF (-25ºC - 80ºC)
Warranty: 1 year
Torxe™ - AGM Factory Activated Battery
Features:
Advanced AGM (Absorbed Glass Mat) technology
Maintenance free, never needs water or terminal cleaning
Low resistance for high current delivery on-demand and fast starting
Pure lead plates and large plate area provide high cold cranking amps and reserve capacity
Can be repeatedly charge/discharge cycled at up to 80% depth of discharge
Vibration resistant
Spill proof
Strong, durable plastic case
Click on the image to enter the product page at MOTORCYCLEiD.com.
To browse the full catalog of Torxe products, click the "Shop Now" button below:
Or use this link
Give our sales team a call at 888.903.4344 (Toll-Free) or 1.732.867.9995 (International) and we'll answer all your questions.​
1 - 1 of 1 Posts
