1 - 19 of 19 Posts
VRSC est -03
It must have been the late summer of 2005. I was riding in southern Sweden and the dealer in the area there had just received the new model of V-rod, more specifically a sportier variant (R), with upside down Showa fork, larger fuel tank, Brembo brakes and a higher ground clearance. I walked into the store with high expectations. And came out 10 seconds later. Disappointed. What had they (MoCo) done with the VRSC model ?? Sigh!
I must be a little late in the trigger, year 2016 there is a used 2006 R in the garage at home. My. A little shabby in the look, some wavy brake discs, pitted aluminum. On the plus side 1 owner and 6k miles since new. It's time for some TLC ...
Wheel Tire Fuel tank Automotive fuel system Vehicle
To be continued.
2006 VRSCR Street Rod
Wow you and I have a similar history with the R. Only difference is I picked up mine in 2018. Our bikes even look the same! Next year I'll be giving mine some TLC as well. I'll be staying tuned to see what you come up with for yours. Cheers!
VRSC est -03
Wheel Automotive tire Synthetic rubber Automotive design Hubcap
Wheel Tire Automotive tire Light Tread
Not spotless but way better.
Tire Wheel Automotive tire Automotive lighting Tread
Had a floating disc collecting dust, now back in service...
Tire Wheel Automotive tire Locking hubs Vehicle brake
Auto part Gun accessory Trigger Nickel Metal
Natural material Auto part Metal Composite material Nickel
Then the Akrapovic header was TIG`d & extended by 4" so the rear heat shield would clear the footpeg. Yes, the brake lever clear too.
Luggage and bags Bag Musical instrument accessory Sports equipment Auto part
Tire Fuel tank Vehicle Wheel Automotive tire
Great Knut! Your new extended portion will be close to fixing threads in lower frame. Maybe neat support from under is way cleaner than hanging from the passenger peg?
VRSC est -03
Discussion Starter · #12 ·
Mukle: Its been done :) .
Had it pc`d at a local business here in our small hometown.
Bracket not as good looking as RBabos, but holds the can well. Stainless bolts`n washers.
Bumper Tool Motor vehicle Bicycle part Auto part
Tested out a mod "B" handlebar riser and speedo housing, conclusion still poor visibility.
Had to change the fluids and gaskets too...
Automotive lighting Gas Motor vehicle Sports equipment Personal protective equipment
Nasty clutch fluid!
Automotive lighting Motor vehicle Automotive design Automotive tire Fluid
Automotive lighting Rectangle Automotive exterior Bumper Auto part
Mostly for the look - drilled a couple of holes thru the linkage.
Motor vehicle Automotive tire Automotive design Automotive exterior Rim
The temporary sidestand rubber bushing has now been replaced with a genuine H-D one.
VRSC est -03
Discussion Starter · #13 ·
Some emblems made by Biceps.
Before:
Wheel Tire Automotive tire Locking hubs Motor vehicle
After:
Wheel Tire Crankset Automotive tire Motor vehicle
Black levers.
Before:
Automotive lighting Bicycle handlebar Vehicle Automotive tire Automotive mirror
After:
White Light Black Camera accessory Bicycle handlebar
Some minor work on the side stand:
Wood Bag Office supplies Collar Sleeve
Replaced the neck bearings:
Automotive tire Automotive lighting Serveware Audio equipment Kitchen utensil
Some spots with the MIG and the outer races pretty much drops out.
Yes, I did mask/cover the front end of the bike during the "welding" session...
Sleeve Personal protective equipment Tints and shades Collar Gas mask
Time to upgrade:
Tire Automotive tire Bumper Automotive exterior Gas
Drilling and threading session:
Automotive tire Bumper Fender Rim Bicycle part
Voila. A zerk nipple.
The neck head is originally of the closed type, ie the frame is not filled with grease :).
Tire Automotive tire Drinkware Gas Fender
  • Like
Reactions: CycleSavage
VRSC est -03
Discussion Starter · #18 ·
Hood Automotive tire Motor vehicle Automotive exterior Tints and shades
After further disassembly of the bike, it was time to go black ..
Motor vehicle Automotive tire Bumper Machine tool Gas
Natural material Wood Musical instrument Circle Metal
Automotive tire Motor vehicle Bumper Hood Automotive wheel system
Parts back from the powder coater.
White Light Black Rectangle Sports equipment
New bushing for the brake pedal:
Bicycle part Bicycle handlebar Gas Vehicle Auto part
Bicycle part Bag Personal protective equipment Rim Bicycle chain
The new upgraded version of the tree with steel stem. And washer/nut.
Kitchen utensil Tool Gas Metal Kitchen appliance
Looks great Knut. Will the rake angle be same with new upper tree?
Also did they sand or soda blast painted parts before powder coating or can it be done on top of previous finishes?
1 - 19 of 19 Posts
