I guess you could call it a MegaLine. Taking a cue from FLEX400, I had a collector made rather than going the modded 3d volume (which I may eventually do anyway). Well, although the collector has a turn in it, it's still too straight to use the stock heat shield. I hand-formed a sheet of stainless steel and made a heat shield. It's about 14" long and wraps almost halfway around the pipes it covers. It anchors at a nut I had welded at the red dot in the second pic below...
At the rear, it rests on the can. It's fairly tight, but since it's so long, I think I need to anchor it towards the rear. I'm thinking about having 2 nuts welded flush on the leading edge of the can so 2 more bolts can secure at the green dots above and below...
Thoughts?
Thoughts?
