'15, V&H slip ons topless, HD free flow air cleaner. Found a map on here that was very close to my setup. Acceleration ok, not great, popping on decel, but the idle "hunting" was gone. (Small steps) I did a flight recording, and played back on laptop. Was not able to figure out how to allow software itself to generate needed changes, despite Ron's suggestion. (I'm missin something here). Anyhow, I modified the map. Changed air/fuel map to be straight across the board 13.2:1. Also advanced timing front and rear, across the board by 3%. Uploaded, did about an hour flight recording. Acceleration is incredible. Idle good. The 02 sensors front and rear rear very close to each other throughout band, which want the case before. I am VERY impressed with my shot in the dark. Still pops on decel, but not as bad. Any position of throttle other than all the way back to idle, popping goes away. While I'm certainly no expert, I'm pluggin away. I'm aware this isn't right, but that thing RUNS...........
Thoughts are more than welcome, and VERY MUCH appreciated. Thanks in advance.
John
John
