1 - 13 of 13 Posts
I have a 2003 VRSCA with 25K miles. Hear is a GOOD EXAMPLE of a burned up clutch. Replaced with stock and the AIM plate. WOW what a difference!
Friend of Max.
So Greg, I think you found your problem.
Please PM me your address, unless you don't want to sell your Triple Trees. ;)
I've got a matching set of those :slap:
Yeah, The crazy thing is the clutch did not feel like it was slipping only when I hard launched it.
How was relacing the clutch? I'm going to replace mine and looking for some feedback.
Not bad. The hardest part was removing the exhaust. And getting the clutch hub nut off. The rest was easy straight forward. Get your self a manual and follow it. Good Luck!
Gotta Blast!
Greg,
Thanks for showing this to us. You said you went with a stock clutch again, but the plates look different. Did HD change the design?
Mine does the same thing only slips or delays on a hard take off. I was going to have my clutch replaced next month. Dealer wants $600. to do it. What is an AIM plate and does it make it hard to pull the clutch in? Does the AIM plate make the clutch last longer? :notworth:
Another Ski season
AIM reduces clutch pull effort by about 1/3 to 1/2 I think, as far as wear I know not
Those are some pretty colors. Who painted them for you????:D
Discussion Starter · #12 ·
roxxley-rockets said:
Greg,
Hey Roxx, those are the original stock plates. I replaced with stock and installed the AIM.
Discussion Starter · #13 ·
1 - 13 of 13 Posts
