1 - 7 of 7 Posts
Has anyone modified the Muscles front signals from steady "on" to blinking only when activated by the turn signal control?
Can this be done???
It should be possible as here in Australia they only blink (we don't have running lights here - not sure why, but suspect it is law)
It should be as simple as disconnecting the pin for the running lights. I have done this to all my V-rods and never had a problem and can simply push the wire/pin back in to activate them if I had to.
I'm pretty good with hardware stuff, but timid on wiring! Can you provide a quick geography lesson so I know where to find the pin(s), or should I invest in a manual at this point?
thx!
... Can you provide a quick geography lesson so I know where to find the pin(s), or should I invest in a manual at this point? ...
The published VRSCF front signal schematics aren't clear but I attached a picture that shows what should be there.
Connector [31] could have 6 terminal positions instead of the 5 as I show (position 6 would be another BK ground wire). The published schematic shows the front turn signal module with 4 wires going in (V, BE, BN, and BK) and 4 wires going out to connector [256] as shown. If you disconnect the BE (blue) wire in connector [31] position 3 that's going to the front turn signal module then the running light feature should be eliminated.
The front turn signal module, and connectors [31] and [256] are all under the left upper front side cover.
Thanks!
I'll try it this weekend.
Finally got around to doing it (been too cold to ride). Works perfectly, thx!
Added some Wizard lights too!
1 - 7 of 7 Posts
