www.badpenny.org
I think the front axle is a different diameter , so you'll need to play with bearings I should think....
Steve
Tie One On
The rake is not the same on the two models so I am not sure what you would need to do. Someone more knowledgeable should ring in soon on that one.
drag racer
the neck bearings could prolly be found that would make most any front end work.
