This is only my opinion based on experimenting. Timing verification is the only 100% safe method. However, unless you heard a crunch or snap in this small amount of rotation, nothing bad happened. When I did my valve shims and all was exposed, I tried the reverse rotation. Stator cover and valve covers were off. Mind you my secondary tensioners were fairly snug in adjustment and although the engine due to reversed chain guide pressures hates turning that way (friction from chain guide pressure) in one revolution it did not jump.
Also remember, when you turn your engine off , it will reverse compression rebound up to 60* but what saves it from jumping there is the secondary chain tensioners have residual oil pressure to keep the tensioners tight. Otherwords each and every Revolution at shutdown does a small reverse rotation, accompanied with that funky starter whine at the same time as the reverse grabs the starter clutch.
Thanks Ron, I’m glad you’re still on here bailing unfortunate souls like myself out.
The copper timing links were in view on the triple gear for the front cylinder, which is the
”outer” chain. Torque wrench was set to 204 inch pounds (17ft. Lbs. X 12). Cleaned up gear threads and blew them out. Little dab of red loctite on the clean bolt and proceeded to torque. The triple gear moved and I saw the copper timing chain links move about an inch.
Sorry for the long explanation. I just wasn’t sure if you read all of the other posts: I usually don’t.
so what I would be looking at doing, would be timing the cams, correct?. The crank did not move. I had the bike in second, actually I think it was third, Gear.
I’ve also got 15,000 miles on it, so I might as well do the valve lash as well.
Am I correct? Is there anything I’m missing. Sorry to pick your brain. I love this bike and can’t afford another With my tool truck costing 175 to fill with diesel.
