I installed the WEGO & Twin Scan system. Found one of the Bosch sensors was bad. It would not calibrate in the open air setup. Swapped it with the back one and the port worked. I will call then next week for a replacement.
The question here is how to obtain the data. The system records the last 12 minutes of data with the WEGO function active. So it looks like I will have to carry a lap top with the program running in real time mode to recover enough data in all of the ranges. Has anyone tried the software to see if it will work on Windows CE or Mobile? It would be great if it has a usb port on it where you could simply plug in a memory stick.
