VRSC est -03
Hard to tell from here, but can`t you use them as is? 0.7mm extra clearance shouldn`t be a problem.
Edit: If making new bushes I would make them out of stainless steel.
They can be made out of mild steel if desired and you can at the same time match the hole for the id for the stock bolts. The compression mounting as it is, any bending would occur the normal place on the stock bolt so no gain in fancy ass materials. SS would eliminate the need to paint them however. Stock bushings are plain old plated mild steel as well.
