Is it possible to convert my 2004 VRSC from front controls to mid controls using oem Harley Parts. Thanks... you got it.
Street Rods (VRSCRs) and "original" Night Rods (VRSCDs) have Mid Controls, i.e., under you instead of out in front.
All other models have Forward Controls.
http://www.1130cc.com/forums/showpost.php?p=1896963&postcount=14Is it possible to convert my 2004 VRSC from front controls to mid controls using oem Harley Parts. Thanks
I can't say for sure as I went the other way (mids on a D to forwards.) IMHO the original third volume will get in the way of mid controls. I'd check the classifieds for someone selling the pipes off a D or an R. All you should need are the third volume and the cans.Thanks Ken, Will this set up work with my original exhaust, Everything I have seen requires a different exhaust system to clear the Brake assembly . Thanks for your help
Is your bike an A or a B? ( Silver frame=A, Black frame = B). If its a B , I'm looking to convert my 08 VRSCD to mid controls. Frame color is important since the lower right frame piece needs to be changed. Its possible we could swap parts for no money, otherwise its over $500 in parts from Harley. I have an ad in classified in the swap section.Is it possible to convert my 2004 VRSC from front controls to mid controls using oem Harley Parts. Thanks
Thanks for your response, Mine is an A , silver frame. On the side where the shifter controls would bolt near the little triangular frame part mine does not have any provision for bolting the oem bracket to . My understanding is that it wont work with the stock exhaust either???I would really like to maintain the stock exhaust and just have it V-Modded, again not sure if this can work . If it can for sure I would consider it ..Is your bike an A or a B? ( Silver frame=A, Black frame = B). If its a B , I'm looking to convert my 08 VRSCD to mid controls. Frame color is important since the lower right frame piece needs to be changed. Its possible we could swap parts for no money, otherwise its over $500 in parts from Harley. I have an ad in classified in the swap section.
