1 - 7 of 7 Posts
RIP ALEX
Doing my 10K Oil change today. When I pulled the drain plug, I found 2 slivers of metal on the magnetic tip of the drain plug along with sme smaller debry. They were good sized. I have not noticed debry this large on my previous oil changes at 1K,5K,6.2K, and
7.5K. Motor runs fine and uses no oil not antifreeze. I have been have down shifting issue though when in higher gear. Going to cut open the filter and see if there are more metal shavings in there.
RIP ALEX
I think I kept 1 piece. Ill try to get a pic
If they stuck to the magnet that means they aren't rod or main bearings. If you can post pictures maybe someone will recognize what they might be from.
RIP ALEX
Thats good to know its not rod or mains. Ive got a pic, but cant get the camera to focus very well. When my GF gets home, Ill use her camera.
Here are the crappy pics
The Hawk
Probably chips off the trans gears corners, that will happen sometimes when power shifting, etc., usually not a big problem unless you start seeing a lot of that debris.
Mike
I've had those exact shavings too. No big deal, I think.
1 - 7 of 7 Posts
