1 - 7 of 7 Posts
when I re installing the maxi fuse I get a spark and the fan begins to run until the ign is turned on then back off is this normal?
Pat (Patrick!)
Some bikes do that, I guess as a system check. MY '04B does not do it, but I have read it here a few times.
H VROD 5
'05 VRSCB here, mine does not do that. Stands to reason that it would spark a bit thought after all it is the main fuse between the battery and the rest of the bike. The fans running briefly could just mean they relay kicks in due to the computer/system flaking out when power is applied. If it goes all back to sleep afterwords then I would say you probably okay. Model and year, others will confirm for you I am sure. Everyone here is great, and here to help as I am reminded from time to time.
1 - 7 of 7 Posts
