No need to take my file ... if you're paying the money to have it dyno tuned, they will do all the work to create you a fresh MT7 file of your own, specific to your bike.
My file is for those who will not be visiting a dyno tuner anytime soon, has very similar mods and exact same bike (V-Rod Muscle), who want a tune that will make their bike run efficiently and safely (for the engine) in those throttle position/MAP areas that are most commonly reached in every day street riding.
It's impossible to VTune a bike on the street and safely (or unsafely, for that matter) hit all VE cells long enough to capture enough relevant data.
A good dyno tuner who is up to speed with the TTS MasterTune will know how to properly tune the vital tables, most vital being the VE tables for front and rear cylinders. On a non-VRSC bike, they CAN do this with a dyno equipped with a load brake and use the VTune software. On a VRSC bike, they can do this too, but only up to 6500 RPM (plenty for most airheads, but not for us) -- the system can't capture data above those RPMs using VTune. side note: For me, using VTune on the street, I have to rely on the VTune data that I can capture up to 6500 RPM, and rely on the basemap tables for anything above that. Not the best scenario, but its out of closed loop at these high RPMs and the target AFRs are low enough that they're dumping quite a bit of fuel in these areas, especially when considering the Accel Enrichment tables and/or PE mode tables. It's not tuned for maximum horsepower for sure, but it's most likely not going to cook the engine either because it definitely should be getting enough fuel based on what the AFRs are set with the basemap for a (supposedly) similar VRSC setup.
All that said, a GREAT dyno tuner who is up to speed with the TTS MasterTune will know how to properly tune all the vital tables and will use an exhaust gas analyzer of some sort in order to perfectly dial in your VE tables on a VRSC bike up to the redline.
One of these days, I'll have a nice dyno and gas analyzer in my garage, making all of what I just said make just a bit more sense to me. All the information I just typed above may require correction by someone with more experience. My knowledge (aside from minimal VTuning) is strictly from reading, LOTS of reading.
