1 - 17 of 17 Posts
Dean
Does anyone what size nut I need for the lower shock bolt? I am hoping that I can just pick it up at the hardware store.
I have an 08 AW.
Thanks...
My 2007 manual lists it as Part number 7433M (Metric) M12x1.75 flexlock.
From the parts catalog 3074M TBHCS, M12 X 1.75 X 70 LG.
the 7433M is the nut you need for the lower right side.
Of course it migh have helped if i read your post for the nit not the bolt. LOL
Dean
Thank you both, I will try to pick one up in the AM at the hardware store. If they don't have it ....I will have to go to the dealer!
ACE hardware should have them.
ACE hardware should have them. It is actually referred to as a "Castle Nut". Harley calls it a "Flexnut"
I was thinking that the "flexnut" was a self locking nut. Whereas a "castle nut" is not locking and is designed to have a cotter key through it.
You definitly want a locking nut on the shock bolts.
What is on my bike is a "Castle nut" but Harley calls it a "Flex Nut". It looks like a castle nut but it requires torque to thread it on the bolt. It does not thread on via fingers. So I guess it is a flexing Castle nut.
Dean
I was able to get one at Home Depot (I believe it is a flex nut). I took the bolt with and I was only able to finger it tighten it a couple of times.
It does require some torque to completely tighten it. I also used some locktite....just to be sure.
I will check it every so often.
Thanks again for the help.
You're old enough to know better.
:D
Yup ! Thats why I paid . Thats a shallow nut for one its size . And clearance is sparse . There is a large supply house round here but it was not worth the trip .
Oughta be interesting to see if some one comes up with one that fits the bill .
I so hate buggered up nuts :banghead:
Dean
Discussion Starter · #13 ·
:D
Hmmm...:hmm: the one I got at Home Depot, is a bit deeper than the stock one..but there is some clearance (very sparse as you mention above) so it is not hitting the pulley. I am starting to second guess my purchase.
It was less than $2. Hopefully it works
I just went out to the garage to look . Yup its close on both sides .
Duck tape may be your friend during the install ! Then if all goes well . Hope it dont rust ! :)
Did I tell ya I like stainless ?
durata membro
Last one I bought from a Stealer . Stole $12 from me for it
Any and all dealers sell fasteners for a high price.I called for some flywheel bolts on a Dodge the other day,$10 each,X 10.I went to the bolt store and got the exact replacements for 23 cents a piece!
The shock nut is a flex lock nut.
A castle nut requires the use of a cotter pin for safety.
Yea but ! At least on the older bikes . Thers a narrow margin for error , I bet they made em that way to justify he price
you could always treat the nut to the grinder to shave off a few mm
1 - 17 of 17 Posts
