Super Moderator
Any ideas??? ...
Your profile indicates you have a VRSCDX. These have an H4 bulb with both the low beam and high beam in the same bulb. If your tail light and front running lights work and you're sure the low beam filament in the H4 bulb is OK, it's either a bad wire connection in the low beam circuit or the headlight HI/LO switch is bad. (VRSC bikes don't use any relays for the headlight.)
Pat (Patrick!)
I had a wire break on my '04B. The Harness is too tight where it comes around the Steering Neck.
Registered Insane
Yeah happened to me, too, the break was almost impossible to find. The copper separated inside the insulation. Found the weak spot and soldered it. They really don't leave enough room.
