I recently got the Fuel Moto Micro EFI with their preloaded map for my setuo, but haven't installed it yet. Just to be on a safe side I'm looking for someone who has the same or similar setup with an already testet map.
Setup:
2002 VRSCA
V&H Comp. series 2 in 1
K&N Filter
Top on (no mods).
Thanks
Discussion Starter #2
Still looking for someone to share their map.
Update:
I've installed the Micro EFI Tuner and had been riding around for a few weeks. This is what I noticed:
  • The fuel consumption increased - after adding the V&H exhaust and the Micro EFI now it's 29,4 mpg. Before, without the Micro EFI and without the V&H exhaust, it was around 37,63 mpg. Previously I ran K&N air filter and Screaming Eagle 16ga. double barrel (the same as V&H double barrel) exhaust without any tuner.
  • The exhaust, when the engine is running, is shooting black wet soot (Maybe it's running too rich and that's the uncombusted gas)
  • Sometimes in 2nd or 3rd gear, around 3000 rpm there are moments when the engine "dies" (it's seems like for a moment the cylinders don't fire. It happens momentarily and for a split second, but the engine keeps going).
  • When engine breaking there's some loud popping rumble when below 3000 rpm (if its more than 3000 rpm the rumble is normal).
Any advise would be appreciated.
What about getting it dyno'd?
(edit) Sorry, you probably already thought of that.
Regards,
Sent from my ONEPLUS A3000 using Tapatalk
Discussion Starter #4
Regards,
There are only a couple of shops that offer this service to motorcycles in the whole county (It's quite small) and I'm not sure if they had much experience with Harleys and especially V-Rods.
