1 - 9 of 9 Posts
Need sugestions for installing lights, hiding the wires,connecting to fuse block or battery, and locating on-off switch. Thanks AL
Motor Lights
I put two lights on each side above the cams. Wiring is real easy as you can hide everything under the airbox cover. make sure to shrink wrap everything.
Which lights did you use, and where did you mount the switch?
V-Rod Addict
Post some pics...
Greg/Moderator
Mounted the switch in side the horn cover switch had 2 sided tape on it....work good and you really can't see it.
Big Daddy!
I put the switch under the seat where is out of harms way, so only you can turn the lights on. You can buy the fuseholder clips from harley, then use one of the spare spots in the fuse block for your extra lighting
1 - 9 of 9 Posts
