Greg/Moderator
My light is loose and rattles. I looked through the service and parts manual and can't figure out what holds it in place ? Theres a hole in the center of the light but the 2 manuals don't show any screws. I wanted to ask before I pull the rear end apart.......Any help would be great ?
Thanks Greg
iTrader Technician
If I remember correctly, it is just held in place by the dogs ass. The hole is so you can stick a screwdriver through it to remove the brake light.
Will Work For Mod $$
The light has two plastic tips ( one on each side) which fit into grooves in the dogs ass. Use a little clear silicone sealant on the area where they connect. It will keep the light from moving and easily removed if you have to replace the light.
