1 - 15 of 15 Posts
G'day from DownUnder
I have bought a replacement set of levers from cyclesmiths. They haven't arrived yet and I wanted to canvas the general forum for installation tips in case they don't come with instructions. The retaining pins have c-clips on them so once I remove them they 'should' slide right out? Right? Will I have to bled the lines again afterwards?
Happy to be corrected and any advice is welcome. If you have a spare moment go to http://www.sprintex.com.au/Harley_Davidson_V_Rod_Supercharger_Kits.asp
and check out the kits. I got my supercharger through them and their after sales service has been nothing short of exceptional.
Cheers
1130cc Ninja
pray that they are right... i got the HD levers for my AW and they wouldnt work, I double checked the part numbers and all, maybe they packaged the wrong ones up.. not sure
Freedom
DallasV Rod said:
Get a shop manual. That thing will pay for itself time and time again.
:them: :thumb:
EXCELSIOR
Cheers
Your dis/reassembly impression is correct and you will not have to rebleed anything.
Get the right sized set of ring pliers and be gentle with them as they spring easy. The good thing is they can be re-arced as easy with some neednose pliers.
Follow the advice above , get a workshop manual, the real deal not a clydes etc.
It is an EZ job to change levers. Only hard part is finding the mini clips when they fall on the floor.
Be careful with the cyclesmiths levers. I had a set on a Road King, no amount of adjusting could get the brake lever in correct position to work properly. 5 others interchanged and worked fine but the Cyclesmiths never fit.
I'm not knocking Cyclesmiths, I like their products and have their floorboards on my DX but some of their levers are defective
Non-erator
I bought new C-clips (or did they come with the levers).
There's also something about having to put a 3mm piece of cardboard where the brake lever hits the plunger or you will suffer unbearable pain and die or something like that. (Seriously)
Buy the manual!!!!
Buy the manual!!!!
new c-clips YES, but you never seen the floor of my garage
The cardboard curse.......yes but it can be broken by using the eye of plastic cable tie.
Non-erator
That must be because you've never invited me for a beer in your garage! :stilpoke:
My garage got broken into a few years back. The only way we could tell was they cleaned the place up
The beer is waiting..........bring a ba.........room
I thnk we should give Ben his lever thread back. I'm headed over to Babaloo's or whatever it's called for a jugg of beer, the place that was Olivers in Hudson, thats now owned by the former owners of Bourbon St West
Non-erator
I could go for a ride... how long will you be there?
Discussion Starter · #13 ·
thanks for the advice folks, I have a manual and the cyclesmith levers did come with instructions. You have to be careful about not damaging the brake rubber boot or something so you can't just slam the brake lever in. They went in without a hitch - the hardest part was getting those dastardly c clips off and on. I even bought some pliers but they were too big. Looks great now. I installed an airhorn from Howards Hogs Horns too. A little modification - wired them up and now I can let people know EXACTLY how I feel when they cut me off. I will post some pics if any one is interested...
Thanks again for the help guys
Cheers
Grog
Air Horns!? Holy crap - I scare Hyundais with my stock horn!
Now, tell me, Ben, in your little pic...is that a model VRSCA? Very cool!
Grog
BrisVegas
Discussion Starter · #15 ·
Little VROD
Hi Grog - Yes,
In the pic I have a remote controlled VROD. My then girlfriend - now Fiance got it for me. It is a little corker. I have seen them in Morgan and Wackers on the Gold Coast and they are as dear as poison, but she got it off ebay. She does great work - I got the chrome slotted belt guards for the valentine's day before last so I'm going to hang onto her ;)
Cheers
1 - 15 of 15 Posts
