MYDRM
I just purchased a kit of leds from custom dynamics and I want to do the best job of running two of these up to the front forks. :confused: Can any come up with or have a idea of how to make it look good. :cool: I would like to make the wires look like they belong there by running them through a tube or something? Any ideas would be great! :notworth: Thanks Clark P.S. These are cool lights I take some shots of it when its done. Thanks again Clark
What sort of kit is it, and what to the lights look like. post some pics, and explain what exactly your trying to do
MYDRM
here they are
http://www.customdynamics.com/wizard_lights_color_changing_led_accent_lights.htm
This is the link. I was just out checking them over and I think I will hook them up on the black section of the radiator shroud or what they called gumbys casket! there is a black section that these fit good into. now I want to get them on a small slant so you can't see the lights!Here is a shot of where I think the front is going. When they are on each side they look good even with the lights showing! Thanks Clark
I would say get some black wire loom. Run the wire to the brake line, then wrap the wire loom around the brake line and run it down to the caliper...
