Hi!
I purchased the following LED turn signals to install on my VROD (06 Nightrod):
Drag Specialties Black LED Handlebar Marker Lights with Smoke Lens
Also bought a set of load equalizers to go with it:
Joker Machine LED Turn Signal Intensifier Converter
Installed the left turn signal to instructions, LED would act as a running light and a blinker. However, it starts flashing at a normal pace then after 3 flashes it goes quickly. Wondering if any of you have had this issue before.
I haven't installed the right blinker yet, would installing it solve the issue? Don't want to cut the old turn signal before I get an answer.
Thank you.
Talk to the boot!
I had issues like this when installing LED lights for the blinkers once. The blinker controller thinks the LED is a blown bulb, so you get the fast blink as a warning. You can get a wiring converter that keeps the blinker controller from freaking out, has some circuit in it to stop it. They're known as "load resistors" so you should be able to find a compatible unit and shoehorn it in!
Good Luck!
-I see you got the load thingie... Perhaps you need to do both sides for it to work properly, that I don't know.
Hi!
Thank you.
BT801 Smart Equalizer
Update: After installing the second LED indicator the problem was fixed. Thanks for the input everyone!
