1 - 7 of 7 Posts
I am installing LED lighting for the front and rear turn signals. Is there a way to disable the BAS (Bank Angle System) on the bike so that my blinkers will not blink rapidly? I usually turn off the turn signals before the system does on my bike so it really isn't a necessary option for me to have. Also, will removing this system from the bike mess with the security system?? I have heard that it is a integral part of the system...
It's not the BAS, it's the alarm/tsig module seeing low load which it interprets as a burned out bulb. You need load equalizers installed
Ed
H VROD 5
If you don't want to drop $60 and are not afraid to cut your wires, you can make up your own with a couple resistors and diodes. Probably 5 bucks from radio shack. I found a link on how to DIY, when I get home I will pass it along.
Friend of Max.
I prefer the solid state Biketronics module to the resistors. Resistors build heat. I know you're only using them on your turn signals, but still, there isn't any good place to put heating resistors under your fenders without the potential to cause problems.
Discussion Starter #7
If I were more confident in my wiring abilities I would go the cheaper route but I will drop the $60 to get the module. Thanks though
1 - 7 of 7 Posts
