Has anyone else had a clutch resevoir that leaks around the screw heads? mine has always barely leaked around the right screw head...just enough to see that there is fluid around the top of the screw, but not enough ever to drip off the top. The first time I had it in the service dept. they changed the rubber gasket. The next time, the changed the whole cap of the resevoir. I've tried swapping out the screws and also turning the gasket 180 degrees...still it's seeping out the screw hole. It must be a warped clutch resevoir I'm thinking. I called them and told them it's still leaking and they were going to consult HD, but it looks like a new clutch resevoir is next...I was just curious if anyone else has experienced this.
