1 - 14 of 14 Posts
Vrod-Mike said:
That looks like it's on the old narrow fender. Probably won't fit the new wide fenders.
web page says '02 to '07 so I guess you are right but I was hoping someone here called them and got a updated one for the 240 rear ends.
Chief
I placed mine on the actual fender. Drill three small holes and bolt them on, they look better than adding the extra metal underneath.
Contacted LazerStar today and they said they do not have one for the large tires but are working on one. He also said it will be a couple of months before one is available.
Guess I will make my own.
I installed lazer stars directly to the fender.
Y'all have the small fender. The fender on my 2007 vrscx is a full 3" wider thaen the base "A" fender.
I meant I drilled holes in my fender to attch my lazer stars (would not put that ugly bracket on my bike). No turn signal brackets on my bike - signals are tucked away as to only be seen when signaling a turn. Turn signals ruin the lines of bikes - they suck.
nic_a_bod said:
That tag is a rip off for what it cost imo. Halfnutz67 has a template to make a tag holder that cost about 10 bucks and looks great and very easy to do your self. I did mine out of flat stock not the diamond plate.
Here is the link http://www.1130cc.com/forums/showthread.php?t=23345&page=2&highlight=hafnutz67
I'm not looking for a LP holder. The other item for $99 is sans LP holder. It wraps around the fender and has holes for tail light mounting.
I have a set of black turn signal mounts for the back of the bike. They are the VMOD ones that attach to the shock mounts. I paid something like $90 for them - you can have them free if you want to go that route.
Army spark jockey
PM Sent
Discussion Starter · #14 ·
nic_a_bod said:
oops my bad
Your forgiven. Thanks for the comments however. I agree that the money for the LP version is a bit much. I have a side mount for my Tag but I do not know if I want to keep it. Will keep halfnutz67's version in mind.
1 - 14 of 14 Posts
