1 - 10 of 10 Posts
Autobanmod
I'm looking for a lamp mask which supports three 52mm (two inches diameter) round instruments.
Maybe something like this is available somewhere?
I know of solutions where the airbox lid takes the instruments but I don't have space for that and am really looking for a lamp mask equivalent.
Autobanmod
Discussion Starter · #2 ·
Don't let me do what I plan to do if I can't find such a lamp mask :D
Combining a Wok with three cocktail shakers...
Autobanmod
blink blink, that's how it is now
The oil gauge has different colours to choose from for following settings:
a) low pressure warning
b) normal operation
c) high oil pressure
it also has an output for the ECM
Stack Instruments, nice :)
09 vrscf
does this lamp mask even exist for other bikes? Is this the correct term for it also? I'd love to help scourer the internet with yeah...Thanks Mike
Autobanmod
It's called "Lampenmaske" in German, there is probably a different term in English.
I've spent considerable time searching for that and didn't find any.
In car dashboards or aviation it's called instrument cluster or cockpit.
www.badpenny.org
Hmm - googling for Lampenmaske seems to show headlight fairings.
Is it a triple gauge pod that you're after for 3 x 52mm gauges?
http://www.google.co.uk/products?hl...esult_group&ct=title&resnum=3&ved=0CDUQrQQwAg
Amusingly triple gauge pod in Babelfish comes out as
"dreifache Lehrenhülse"
which becomes
"three-way teaching case"
when you translate that back to english :)
Autobanmod
Yes, I'm looking for a combination of a headlight fairing with a triple gauge pod.
Well well! :D
www.badpenny.org
Well well! :D
Ah , I've never seen one of those. Shouldn't be too hard to bond the gauge pod to the headlight fairing though .
Good luck!
Steve
09 vrscf
ok I think your looking for some type of bezel to hold these gauges or a premade cluster. As far as I know there is no such item for our bikes. Maybe try and reverse engineer a cluster holder from an off brand bike. Check ebay for some ideas of what is out there on other bikes and you just might find something that can be cut down or made to work. Thanks Mike
1 - 10 of 10 Posts
