I'm thinking of purchasing a Killer Glass radiator hose. Did anyone who installed this product have any problems installing it? Did you also wind up changing out your coolant to match the light? Any feedback would help. Is it worth the money?
Friend of Max.
Considering that is my bike (my daughter's arm and hand in the upper left corner), Yes, I have done it.
It's not terribly difficult to do, if you follow the HOW TO by Kennedy.
I would do it again in a heartbeat.
I did not change the coolant. The orange works well with the RED led, and now my cluster matches the light scheme, white with red needles.
RICK
I Hear Rj's Got A Tricked Out Vrod!--not Too Hard To Install. I Have Had One Leak Out Of The Light Fitting. They Sure Do Look Cool!
Sua Sponte
Can you see it through all the smoke, louballs??:laugh: :mrgr:
Very easy to do. Just make sure to really heat up the clamps when you install it. You dont want any leaks.
Premium Unleaded
I used a "real" heat gun, and changed out the coolant with "Engine Ice".
No problems.
Easy Mod.
I did discover that O'Rileys has the Gates clamps for about $5---vice the $13 that HD charges.
I didn't mess up the install, I had to repair my forward radiator hose which was defective as a result of HDs famous QA program!:banghead:
DO IT!
For 150 bones, it's a HECK of a good mod!
:D
