1 - 20 of 22 Posts
Proud Infidel!
Do K&N's produce a noticeable increase in performance and are they worth +$60.00?
durata membro
They do open up a few pent up horses but in the long term of maintenance they are cheaper for the fact you just clean and re oil them.A new recharge kit is around $10 and does 3 or 4 services.
Elrod on the V-Rod
Dark Knight
I went topless with a K&N filter and noticed a decent jump in power. Of course, I also modified the exhaust, therefore need the RT. All in all, there was noticeable difference from the stock filter.
The best thing w/ the K&N is that it is reusable...I don't think you are going to feel anything it's such a small difference
Genesis1130cc
Elrod on the V-Rod
WHAT DO YOU MEAN BY RE OILING THEM?
Re oiling? The K&N filter does not filter at all unless it is oiled. The dirt particles are trapped on the oil, not the dry paper.
Genesis1130cc
How do you go about re oiling them?
It's all in the instructions. You need to also purchase a Recharge Kit which includes a detergent solution and the oil (which gives the filter the red color). Both products are in spray cans, it's hard to to screw up. You'll have to wash, dry and re-oil the element periodically as maintanence.
Genesis1130cc
Cool, thanks. I will investigate a little further it looks like. When I bought the bike it already had the stage 1 w/filter so now I know I have one more maintenence item to perform.
03 A
Where can one acquire the recharge kit?
synseer said:
Other option are the Amsoil nano-fiber air filters. Can buy one through Ken here on the forum. They are just as good and you don't have to re-oil them.
Ed, You are correct. They are easier to use and cost is less in most cases as well. Not to mention no mess in cleaning and oiling.
You SHOULD be able to get the recharge kit anywhere that stocks K&N Filters. Around here, that's Advance, Checker, VatoZone, etc...
Which is better, the K&N or the Screaming Eagle Filters? I have the SE on my V-rod and the K&N on the Avalanche.
I've always been partial to K&N but have no experience with either the Screamin' Eagle or the AmsOil filters.
So, I will :bolt
durata membro
Caution needs to be taken when using the K&N on vehicles with MAS air flow sensors.I don't see it as often as I used to because I don't work in a dealership anymore and the problem is usually cured by the time I get the vehicle in for repairs,the ones I do see now are after a filter service where there has been to much oil put on after a filter service.Diesels are the worst for K&N compatability.The oil gets into the sensor and creates all sorts of driveability issues,including automatic transmission performance issues.Most of the time a carefull cleaning of the flow sensor and a new dry filter fixes the problem.
Our V-Rods do not have these air flow sensors but it's still a real good idea to follow the service instructions in the recharge kit.This is definatly not one of the times where.... if a little is good then alot should be better.
Elrod on the V-Rod
1 - 20 of 22 Posts
