1 - 20 of 31 Posts
VrodG said:
The small turbo's :)
Oh and Mike does NICE work. :thumb:
D'oh!!! Brain fart - I forgot you were building the turbo motor. I'm still thinking of the Jones .480/.455 instead of the Megacycles - there was a nice write-up on how the lash on the Jones takes place of a CR
Steppenwolf said:
D'oh!!! Brain fart - I forgot you were building the turbo motor. I'm still thinking of the Jones .485/.455 instead of the Megacycles - there was a nice write-up on how the lash on the Jones takes place of a CR
I think we are in the same position. I am still deciding on these 2 set of cams.
--------------Duration @ ------Lobe----Lobe
--Part# --.010"--.050"--.200"---Lift---centerline
CR75480__300___254___185___.480"____104
CR75455__300___252___180___.455"____110
or
M77500-In 287°_260°_190°_.500"__104° Stage 2
M77460-Ex 285°_258°_183°_.460"__110° Aftermarket Springs
VrodG, how long did it take to receive the cams after ordering them?
I'm deciding between
and the equivalent Megacycles - both with the Jones aftermarket springs. I think the Jones .500s are too radical for me.
Friend of Max.
:stupid:
Anyone build a motor with these cams in them yet? :wazzup:
rjrivero said:
:stupid:
I don't think so, RJ - I'm guessing MikeP will use the Megacycles, b/c Eagle tends to go that way (his bike is being torn down right now). Maybe some of the Destroyer Crank gang this winter will opt for these cams...
Friend of Max.
I know what you're talking about, Alex. I have been having discussions with Paul Diener re this very issue.
I think I'm going to just buy them, and let Eagle do a comparison for us all. We may as well see what these Jones Cams can do!
The best answer I got from tinman was, "They don't look bad on paper, but we won't be able to know what they do until we put them in a bike." I presume he means my bike ;)
smoothrod said:
Give me a few weeks and hopefully Ill have one with them.
Lonnie - you are building with the Jones .480/455? What bore and stroke?
I'm rooting for you, Man!! Forge on ahead!!!
smoothrod said:
Alex I'm building a motor with a 1/8th inch destroyer crank and 1250 bore.
Keep us posted. I'm looking at these Jones Cams and springs in a 1250 bore 1/4" stroker. Using the CP pistons with the repositioned wrist pins. Should be pulling my engine around the beginning of December.
Bone Stock B Model
My bike is on a stand in the garage with the motor ready to come out. By Saturday night it will be pulled and broke apart.
Friend of Max.
I am curious about your build for a bunch of different reasons. I still haven't seen any numbers on the 1300 with the Destroyer Crank. I would like to know how it runs.
I would also like to know if there is a difference between the Jones cams and the Megacycles re-grinds. It would be nice to see them in the same engine, so we know what the difference in the cams truly is.
RJ
Formerly BobK
RJ
I thought you said you were going to do this also.
1 - 20 of 31 Posts
