1 - 20 of 97 Posts
Several people have ask me about changing them. They seem to wear at a rapid rate, enough so that I stock them in the store and sell them. I went ahead tonight and did a quick video to show how easy they are to replace. The file is a little big for dial up but the size is so you can see better what I'm doing.
The bike is on a jack, do not try to take the side stand off with the bike on it. :)
http://www.1130cc.com/gallery/misc.php?do=downloadfile&i=36434
Ricky Love MooreHead
I'm With Stupid
Thanks Max. My bike didn't even have a bottom bushing or cotter pin when I got it. I got a make shift pin in there for now. Didn't know you offered these but I will be ordering a set in the near future along with the brake/clutch fluid replacement kit (winter work). Robb
Just watched the video. Man that looks so much simpler than a thread I read months ago about putting washers in the spring to lengthen it for easy installation. Oh, I know you've heard it a million times but...NICE BIKE!!!!!
Seriously Max,, thanks for the tip...
Still here, sort of
Hi Max,
Thank you very much!!!
I do not have a collection of cotter pins. Can you provide a little guidance on purchasing the proper one? I would think I should go to an automotive or hardware store???
Lil
Silver Bullet
Thanks for making life simple. I did not know I needed to replace that bushing. You should do a seperate video for each of the maintaince items so we can all do the work ourself. And then create a seperate video section for us to reference. Maybe a seminar at each of the major bike showings for all the VRoders!
You have single handely built a "forum" for us.
I'm With Stupid
Diamond Lil said:
Hi Max,
Lil
When I do mine I think I'll just take the pin with me to the hardware store and get the largest cotter pin that will fit the opening. :)
Scott
Of course you know this needs to be posted in the Tech Service or How to sections!! Thanks Max!
Still here, sort of
Thanks.
Are all cotter pins made equal? In other words, what metal should I get?
I'm With Stupid
Diamond Lil said:
Thanks.
Probably not, but for this application I wouldn't think it would be a big deal, especially if you get the biggest one that will fit. Since they are made to bend I doubt you will find one of real hard metal but I could be wrong. I have a hose connecter pin in mine right now that is stainless steel and won't bend easily but probably doesn't look too good (but only if you were lying on your back). I certainly don't notice it with the bike on the stand.
NOTE: When I say largest one that will fit, I mean diameter. If it's too long you can always snip off the excess if it is an eyesore.
Still here, sort of
That makes sense. Thank you for your patience with someone who knows not much at all about this wrenching stuff. :)
I'm With Stupid
Actually I'm so bad at wrenching you may want to ignore everthing I just said. All I can say is it made sense to me:cheers:
Discussion Starter #15
I purchased a box of cotter pins the other day and a lot of people are ordering bushings today because of the video. I will start including a new pin as long as I have some to make it easier for those doing this for the first time.
Max
Still here, sort of
MAX!!!!!
I'M ALMOST SPEECHLESS!!!!
YOU ARE TRULY AMAZING!!!
THANK YOU!!!! :notworth:
I'm With Stupid
Max
Well that takes care of that! :)
Discussion Starter #18
I'm going to add this to the tech page but thought I would bump it up for any that had not seen it yet.
Still here, sort of
Thanks again Max!!!
1 - 20 of 97 Posts
