1 - 9 of 9 Posts
Chillin' the Least
Looks easy enough but whats the trick to remove and install the spring? Brute force and ignorance? Thanks
Pat (Patrick!)
Chillin' the Least
Jesus, and I fix airplanes for a living :banghead: The stand itself is the tool I need. Thanks Much!
Pat (Patrick!)
My pleasure! (is all that I care about...:D)
There are rumors on other non v-rod forum that if you stick pennies between the coils of the spring it will make it a lot easier to work with. (Stretches it so you don't have to.)
Deleted - double post.
1 - 9 of 9 Posts
