I'm assuming that you don't have an "R". The VRSCR has a traditional airhead-type jiffy stand.
But, for all others, the service manual calls the "tang" on the frame end of the spring an "anchor". The instructions for removal are as follows:
- Block motorcycle underneath frame so both wheels are raised off ground. Jiffy stand should be able to move through its full range of travel without the weight of motorcycle resting on it.
- Remove cotter pin from clevis pin.
- With leg in the retracted position, detach spring from jiffy stand leg and anchor.
- Remove clevis pin by gently tapping on pin from bottom to drive up throught mounting bracket.
- Pull out jiffy stand leg and remove upper and lower bushings.
- Loosen and remove the anchor.
- Remove rubber bumper if necessary.
Because it calls for the anchor to be loosened, I assume that it is threaded like a bolt.
