SpeedoDocter
instructions:2008 reactor front wheel
Do you have instructionsfor reactor rear wheel ? Instructions for Wheel Installation Kit 43861-08 ?
SpeedoDocter
Ok ,had these numbers lying around for som time....
these numbers revert to the general wheel bearing kit mentioned in the instructions above...feel free to add..(like max wished for som time ago)
Lenghts of inner wheel bearing spacers included in the kit:
PN# 43755-04 = 77,20mm
PN# 43641-01 = 94,85mm
PN# 43633-06 = 120,60mm (or 4 3/4)
PN# 43517-00 = 122,15mm
PN# 41345-06 = 152,05mm (rear 06SE2 used in 8' reactor)
(outer diameter 31,7mm ,inner 25,6mm)
PN# 41357-06 = 31,35mm (lenght of 06SE2 pully spacer)
(outer diameter 38mm ,inner 25,6mm)
PN# 40436-01 = 29,85mm(my stock 04 pully spacer)
the wheel spacers for my 06SE2 wheel where 8,1mm at both sides
(the stock small wheel spacer at the caliper side(43571-01) is 8,1mm also)
SpeedoDocter
Discussion Starter #5
Old but still usefull.. :D
Still have the 04 with that reactor and added a Muscle to the stable im now adding all my electronic gadgets on.
(those interested I have all on my 'Dutchcustomled' page)
Angelo.
