What catalog are you looking at? I can't find it in mine.saleen146 said:Just happened to look in the 04 catalog:
29540-03 fits 02 VRSC.......$44.95
29541-03 fits 03 VRSC.........$1.95
strange..........seems to be very different.
I'm I correct reading your post that if my '02 was flashed for the SE Slip-Ons, I do not need an additional flash if I relocte the IAT Sensor???mjw930 said:There's a flash for the '02 bikes that relocate the IAT that's essentually the '03 program. All of the SE flashes assume the IAT has been relocated.
If you can find the part number of the flash I can see if it's before or after the IAT updates. You may already have the correct flash you just need to move the IAT.
I don't buy that. The purpose of the IAT is to tell the ECM the air temp so small changes to the AFR can be made. Cool air is more dense than warm air, and needs more fuel to maintain the same AFR. The PC III is going to make changes to the AFR based solely on throttle position and RPM. The ECM still needs the proper programming to make use of the IAT input.mustanggt said:I was just told by a H-D tech that if you have a PCIII, you do not need a reflash for the IAD Relocation. Is this correct info. I just ordered the complete relo kit for $50.00.....I currently have the flash for the SE Slip-Ons, along with my PCIIIUSB.
