The Heavycycles Guy
...so I can revise the taillight install instructions for the connectors on the wide tire '07-up V-Rods (AW, DX, etc.). Bike needs to be stock in the rear lighting setup.
I'll need you to leave the bike with me for the day (I won't ride it)... I just need to pull off the passenger seat, install light, take pictures, make notes, etc...
**Free Stage 1 Taillight or $100 Stage 2 Taillight (w/pass-throughs)**
Anyone?
Kicking cancer's ass
Only a 653 miles ride.
Hmmmmmmm.
Phil Z.
working on a way to get to petaluma in 1 day (I gotta be to work @ 7a.m monday). I know, send me a tail light and I'll document the install for ya.
Shady
I was thinking the same thing myself zman
Damn - sorry Joe - had I seen this yesterday, i would have snapped more pics, this is the only one I have...but you're welcome to use it - I can email you a higher resolution one if you want...
Brian.
That's the turn signal harness from the signals - btw
I pulled pins 3 & 5 (the two purple wires) to hook up the pass-through. On the mating harness one is brown, one is purple so they match up with the pass-through wires. Because they're both purple on this harness, I pulled one out, put the heat shrink tubing on, connected it to the correct pass-through color (by comparing with the mating harness), then pulled the other one out, did the same. Put the pass-through connectors/wires into the harness, matching the pass-through colors to the mating harness again. Then I moved the tubing up around the connection, tested, then heated the tubing - hardest part was pulling the wires/connectors out of the harness - Hope this helps....
Didn't realize this one was on the camera too - you can just make out the wires in the other 1/2 of the turn signal harness in the lower right...
