Someone tell me exactly how I would go about resetting the throttle position??? This is the response I got from powercommander:
You might try resetting the throttle position, with the bike fully warmed up to normal operating temperature. You could also have the bike dyno tuned and custom mapped specifically for your setup. That is the only way to insure that the fuel mapping is 100% correct for your bikes setup. Thanks
This was my original email to them:
Hello my name is Victor Garmany
First off I guess I should tell you what I got:
2002 V-Rod with Samson street sweepers (no baffles), PCIII, screamin eagle air filter, topless (inside airbox cover taken off)
I'm using the map 809-008
My problem along with others is at stoplights or any sort of stop the rpm's will fall untill the bike will finally just die, it seems to happen the most after the bike is warmed up. I've used different exhaust with different maps and this doesn't happen. I'd rather stick with the samson exhaust but I'm getting tired of always trying to keep the rpms up at stops, so I'm wondering if you guys have heard this problem from others and have made any custom maps? or do you have any advise for me to change the numbers on the map (I'm not very bright when it comes to this stuff)
Thanks in advance for any help you could give me!
