1 - 10 of 10 Posts
Definitely a sad day. Engune seized up Monday and just now got the head 9ff to discovery my greatest fear. Dropped a valve.
Look at pics I am including and tell me if this engine is either toast or repairable.
Thanks in advance
Liner and piston can be replaced but you would need to strip and inspect further to be able to say if it is toast or repairable. The liner looks pretty bad so you need to find out if anything was picked up by the pump and sent down the oil galleries to the crank etc. Most things can be repaired but it depends on how much you are prepared to spend.
Well I see I can get a used engine off ebay for 1600. Then 250 to ship. Put my screaming eagle heads on it. I'm thinking it will cost more than 1900 to fix this one. What u think?
As I said it's impossible to call without further investigation. If everything else is untouched then a piston and liner kit will cost a lot less than that, but..........
Do you know anyone in TX can help me rebuild it?
Those OEM Valves have the heads welded on the stems and are not really up to the original build standard - I'm surprised they got into that Porsche designed engine. I would be concerned about the rod and crankshaft being damaged / weakened as well. The member here BadVRod I believe may still be around in Texas or pull the engine & ship it to Fitzgerald Motorsports he could probably save your red case and install S/E heads with new racing valves even a 1/4" stroker rod for more power. Used engines can be a crap shoot you don't know what kind of forces they went thru if off a badly crashed bike ask for a photo of the bike - miles, comp. check and a warranty etc. Me I'd rebuild what you got put some nice go fast goodies in it now you got something better with new parts for the fast long haul -
I have screaming eagle heads. Many other upgrades.
I have screaming eagle heads and many other upgrades. Including pics. How much for Fitzgerald to fix it?
Automotive lighting Hood Automotive tire Purple Motor vehicle
Tire Wheel Land vehicle Fuel tank Vehicle
Tire Wheel Land vehicle Vehicle Automotive lighting
I have no idea so many factors just call him & see what he says - I'd replace the rods, go to a new 1/4 " crank I'm thinking maybe $ 6000 - 8000 ?
1 - 10 of 10 Posts
