1 - 20 of 51 Posts
Sanctimonious
When I go into second gear and kind of Hit it (Not Racing style just freeway entrance type shite) the bike pops out of second and back into neutral. My Upper gears (4&%) are seeming a bit "Lacking" also around 5000rpm. I Changed plates not more than 10k ago and Just did the Clutch fluid. What the Frig?
Thanx For Listening.
Possibly time for the shifter fork upgrade? I know on the 02-03 they had problems with a weak shifter fork. My 02 was doing the same and also popping out of third and back into 2nd. I had the upgrade kit put in last month. So far so good....
Friend of Max.
Dead on. How do you feel about cracking open your motor Lux?
_NoHighLikeMostHigh_
Dejavue - I thought I was back on the V-Max list. Early model V-Maxes had the exact same problem - popping out of 2nd.
I thought you had the shifter fork upgrade done a while back... I'll have to do some digging.
What did that cost...
If it's just second then I would check all my shift linkages for binding first. If you pop out of all higher gears and it drops back down then that would be a sign that the shift drum ring is loose and time to do the upgrade to the new shift drum and shift forks.
Sanctimonious
Sanctimonious
I dont like that idea at all and now my Tech is gone.
Sanctimonious
Discussion Starter · #11 ·
IS this the same Drum I saw when I did my plates? Forks I do not know.
No David the shift drum is deep inside the trans. It had a washer pressed on the original but later they pinned it so that it wouldn't spin. Reading the other thread it sounds like yours may have been changed already.
Blowin' Smoke
I'd clean and lubricate all the moving parts of the external linkage; if it still pops out take advantage of that warranty!
I would imagine he'd feel more comfortable sticking large objects...well, you get what I mean.
Dunno..... Haven't gotten the bill yet.
Sanctimonious
Discussion Starter · #17 ·
Got the Shift Linkage off and the one side was a very stiff, cleaned the hell out of it, lubed it up with Graphite & Liquid Wrench and we shall see.
Stiff can be good but not when your talking about shifters. :)
Sanctimonious
Discussion Starter · #19 ·
Or when your "Popping In & Out of 2nd" . Hey Now!
Sanctimonious
Discussion Starter · #20 ·
Well that wasnt it, still slipping and all. Now I need to find a New Tech in Socal.
1 - 20 of 51 Posts
