1 - 7 of 7 Posts
Fireman/investigator
My first how-to... how nice. ;)
I was washing my bike yesterday (explains the water spots) and remembered I wanted to move the horn in a bit, like some others have done. Had some spacers handy, so I started to take everything apart. Thought, "hey take pics for a how to". Once I had it apart I saw that it would be possible to move it quite a bit using just what H-D gave us. Soo, here it is...This one is a shot of the horn with the acorn nut removed.
Discussion Starter · #2 ·
this one shows the horn as it hangs from the wiring. I wonder why the wires are criss-crossed like this? Anyway, if you take the horn off and forget, here it is...
This one shows the cover removed from the horn... note the tabs on the cover where the horn mounts. there are 2 nuts welded to the tab inserts (proper terminology anyone?) The tabs go on the cover, then the horn goes on the tabs. By reversing this, you can get about1/8 to 1/4 inch of extra clearance.
take the clips off, then put them on the horn assembly. they just slide on. here is how they should end up, but you will find that everything goes together better if you wait until the end to slide the clips on...
Here is the final product. the horn assembly slips BEHIND the cover flanges, and then the clips slide onto the assembly. the bolts will then put it all back together.
This is a view from the top after putting it all back together. Wires go where they should, by the way. I did take the flat washer and put it BEHIND the frame tab. I don't notice that I am hitting the horn with my knee, and there is about 1/4 inch between the horn and the cylinder. Horn works just like it did before. Hope this helps....
Greg
1 - 7 of 7 Posts
