1 - 9 of 9 Posts
V-Rod Addict
Okay I am trying to change my jiffy stand to a chrome one. Got the old one off and can't get the damn spring on the new one. Any pointers on how to make the spring expand enough to put it on the Jiffy stand?
That's the tightest spring I've ever seen. I tried using a set of pliers and it seems impossible...
Diesel Smoke Tester
first things first
You have to put the spring on first, and use the kickstand as a leverage tool to swing itself up into position for the mounting pin to go in last. It took me several trys to figure this out, but it makes it much easier. Of course, it works best with the bike up on the Lift. Good luck! redrazor
V-Rod Addict
Yeah I agree that probably would have been easier. Using a screwdriver for leverage it was a real bitch!
durata membro
I use a flat screw driver with a square shank and ground a v-shaped slot just above the blade.Fit the driver on the spring put the slot on the hook and just pry it onto the hook.Get your brother to sit on the bike to hold it up and you won't need a stand.
Elrod on the V-Rod
Another way you can put these springs on is to place washers or nickels between the coils on the spring to lengthen it. Just give it a little bend, shove a washer into one of the gaps and move on to the next coil. Saves some busted knuckles.
Also, if you have ever put an exhaust system on a bike that used springs to hold it together there should have been a little hooked spring puller with it. If you know anyone with a dirt bike or sportbike they probably have one.
1 - 9 of 9 Posts
