1 - 7 of 7 Posts
O-FNG
Discussion Starter · #2 ·
Front turn signals
- 3/16" black shrink tube
- 1/4" metal braided sleeving
- 1/2" clear shrink tube
- 1/2" black shrink tube
> Take apart the clamshell housing
> Pull out the metal frame holding the connectors
> Pull out the turns 6-position connector
> Use the masking tape to label "L", "R", and wire colors on connector
> Remove pins from connector
- There is a tab on top of the pins that needs to get pushed down
- SnapOn makes an extractor tool, you can use a paper clip, etc.
- The connector and both turns can be taken off the bike, if you can't
get the pins out, take them to your friendly HD service department.
- This step is the hard part, it takes some time
> Put the wires (3 each) from each turn into the 3/16 black shrink tube
or tightly wrap with black electrical tape.
> Put the 1/4" metal braided sleeving over the wires
> Put the 1/2" clear shrink tube over the metal braid
> Put a small 1/2" black piece of shrink tube at turn signal housing
> Route wires back into gauge cluster mount
> Re-insert wires back into connector
> Plug connector back into socket
Total cost: $10.00
O-FNG
Throttle Cables
> Take off airbox (top and bottom)
> See Service Manual
- take apart right switch housing
- loosen one throttle cable
- take off right grip
- take off throttle cable end below airbox
Hint: do one cable completely at a time
> Put on 1/4" metal braided sleeving
> Put on 1/2" clear shrink tube
Hint: bring braid and shrink tube under rubber boot at grip end
> Cover other end with small piece of black shrink tube
> Re-insert cable into place.
Total cost: $20.00
O-FNG
Gauge Cluster Wiring
- 1" metal braided sleeving
- 2" clear shrink tube
> Disassemble the connectors from the bracket
> Stagger the connectors and snake them through the braid
> Cover with shrink tube
> Reassemble
Total cost: $15.00
spit happens
first step should be to remove the big fuse behind the right side cover. ;)
Those are some good ideas.and they look good. :thumb:
Geez your front end looks great. The more I see of the head light, the more I need to do the same. :vrod:
Unfortunatly, I just got a $4000 bill for the service on the Indian last month!
(Going to take all the caniving I can summon to keep that bill from the wife!) :diablo:
1 - 7 of 7 Posts
