1 - 1 of 5 Posts
I don't believe it is a straight swap. '07 and up bikes had a wider frame in the rear to support the larger fuel tank. The bolt pattern is different between the two types of frame/fender mounts. Possibly you could build an adapter plate that would allow you to bolt the fender to the plate and the plate to the frame of the '06?
1 - 1 of 5 Posts
