Just ordered from v-mod.com:
Rear turn signal/tail light integration set up $104 bucks...
Arlen Ness - Blackness Rad II mirrors
Xenon 65W/100W white headlight bulb
I looked underneath the rear fender... several bolts underneath there, some are underneath the metal fender, some are to the side....
Looks to me like the plastic dog's ass is passively held by plastic tabs underneath the rear metal fender, and bolted to the side. Looks like you just loosen the side bolts and all should fall out... I do not want to remove the fender or rear wheel to remove the dog's ass... is it possible to remove such with a little elbow grease and patience?
I removed my stock exhaust tonight without removing the heat shields, wasnt too bad... but all worked out well....
So what's the best, easiest way to remove the dog's ass?
Nope pretty sure your going to have to remove the seat and fender. Its not really that hard, you just have to be careful where you put everything.
Wore Out Woodworker
Man Its just like my pay check.....................Ain't nuttin to it.
You will need an Abdul Modulating Adjustment tool... I have one for sale for $500... Without it you are in for atleast 10 minutes of work... The hardest part is unplugging all the wires.
