1 - 15 of 15 Posts
You know what I hate?
That bloody horn cover. It juts out and moves my left knee out into the air stream.
I can live with it, but has any one found a less intusive horn cover out there?
Yea, but then you have the mess of wires to look at. Someone needs to come up with something to cover the space that doesn't stick out!
VRRRRRROD!
I agree, makes my knee sore riding bumpy roads or you hang out in the wind. Has anyone moved theirs & done something different like Doc suggested?
Biker Pilot
someone posted a fix to that problem awhile back. You can move the horn about 3/4 inch closer to the bike by using a longer bolt and a different spacer. I just added a few washers and moved mine about 1/3 inch closer. so far no problems.
SNAFU
Has anyone adressed the issue of how ineffective the horn is? Not only would I like to move it, I want to make it actually sound like something other than a toy car :eek:
If they didn't look so bad I'd have air horns on the bike. I want cagers to MOVE OVER when I honk the horn, not ignore me like they do now!!!!!
Making the UK Fatter
Chrome plated air horns !, someone must do them?
Petrolhead
Mjw930, my horn sounds OK. Loud enough for sure . Perhaps it's a 'EURO' specification one. Not sure if they use a different part here but it's a possibility as there are many other subtle differences between USA bikes and my own one.
Probably worth enquiring about part numbers a for Brit spec horn.
Diesel Smoke Tester
A llittle closer, please!
I'm the one that posted the way I moved the horn in closer to the frame.
I put a 3/4" spacer (washers or solid) behind the horn, and used a longer bolt to hold it on. It made a big difference for my short legs! Then I mounted another horn under the bike; where the vapor recovery cannister went. Very loud, and effective. good luck.
redrazor :2cents:
Hi Mjw930,
Got a quick question for you, where are you going to mount the compressor for those air horns? I was thinking about doing the same sort of thing and found a set of horns where the compressor mounts in the horn cover (cow bell) and they have a bracket that places the horns further to the front from where they are now.
Thanks,
Dave
Discussion Starter · #12 ·
Hey Red Razor, thanks for the info.
I'm happy enough with the shape of the horn cover, so adjusting its mounting sounds the way to go.
I know what I'll be doing this weekend.
I'm not sure if there is a UK spec horn Creosote. I do think the horn was a bit quieter than those fitted to my other HDs. It's funny, I was reading a Pommy V Rod test ride, and the bloke said the horn was the best he had ever heard.
Every one has different ideas I s'pose.
Best wishes all.
Ken.
V-Rod Addict
Saw one at Cycle Smiths (909-987-3890). It's called the Finned Horn and comes in chrome with a 100db horn. Anyone know how loud the stock horn is?
SNAFU
VA V-Rod said:
Hi Mjw930,
Thanks,
Dave
I have no idea, I'm not planning on putting them on, just pointing out that they are available.
1 - 15 of 15 Posts
